LW11 Composting Buffer Export
azman_821009
Post by azman_821009 »
Hey guy,
Can I use the new composting buffer export LW 11 in Kray? I really need the Shadow and Geometry Buffer in LW11.
Thanks.
Re: LW11 Composting Buffer Export
hey i dont know if supported with kray i think its negatif . not yet mybe o kray 3.0 i think we have new buffer ex... . but i think u can do it .
u need to do ur render with kray . after do render with lw only for shadow after u do ur composite 8)
i see ur show reel nice work what kind of pc specs u have ?!
azman_821009
thank bro..so i need to render 2 times right? :)
ok here is my PC spec custom:
- Intel i7 Extreme 3960X 3.30Ghz
- Nvidia GeForce GTX 680
- 64GB Memory DDR3
For the animation render, some I sent to Garage Farm.
khan973
Post by khan973 »
The only Buffers you can export, you can see them in the "Kray buffers" panel.
There is no way to communicate with Lightwave.
So yes you have to render twice. As LW and Kray don't behave the same way, be sure that you get the same light.
If you use Kray's sun, it won't appear in LW. If you use Kray's soft shadows, it won't as well. The same goes with everythis that is Kray dependant (like GI).
The passes I usually get from LW are custom Depth, occlusion
