New Open-Source Denoiser by Intel
A place to hang out and talk about everything else...
promity
Post by promity » Sat Feb 02, 2019 9:31 am
https://80.lv/articles/new-open-source- ... -by-intel/
Intel has revealed a new open source image denoiser called Open Image Denoise which is available under an Apache 2.0 license. It is said to feature several “high-performance, high-quality denoising filters for images rendered with ray tracing.”
“The purpose of Open Image Denoise is to provide an open, high-quality, efficient, and easy-to-use denoising library that allows one to significantly reduce rendering times in ray tracing based rendering applications. It filters out the Monte Carlo noise inherent to stochastic ray tracing methods like path tracing, reducing the amount of necessary samples per pixel by even multiple orders of magnitude (depending on the desired closeness to the ground truth),” states the description.
The tool is said to be compatible with Intel 64 architecture based CPUs and compatible architectures. The tool is powerful enough not only for offline rendering but also for interactive ray tracing as well. You can learn more and download the source code here.
https://openimagedenoise.github.io/
promity
Re: New Open-Source Denoiser by Intel
Post by promity » Wed Feb 27, 2019 4:52 pm
DPFilters now with Open Image Denoiser.
Open Image Denoise node for DP Filter
I uploaded the experimental Open Image Denoise node for DP Filter 2018-2019
at the bottom of the DP Filter page,
this is a separate Windows version,
a bit tricky to install,
so it is necessary to see the readme file before,
also because you will download a few dynamic libraries
from the Intel Open Image Denoise Github site.
Denis.
https://forums.newtek.com/showthread.ph ... ost1565794
Post by Janusz Biela » Wed Feb 27, 2019 9:04 pm
I sent this info also to G. He has also two other engines ready to implement into Kray Core.
