Grass V3
Grass V3
Again old instance :(
But ok...primitive tool...good effect.
Scene is big because I put many objects and textures.
So..that is idea, which can be evolve...
Scene for free 8)
Renders without PS, only DoF from PS
http://rapidshare.com/files/414615679/t ... s.rar.html
Re: Grass V3
Post by salvatore »
amazing work! :shock: :shock:
Ies I used this technique too for my grass but your model are amazing
An also the mesh work
I like !
very good work Janusz !
Steel
Re: Grass V3
Post by Steel »
8) thx a lot for sharing. All your work is really big achievement for Kray-Community and i hope for yourself too
Re: Grass V3
Steel wrote:8) thx a lot for sharing. All your work is really big achievement for Kray-Community and i hope for yourself too
Thx!
for me is big pleasure explore possiblites of Kray (this scenes was render 10-15 min, 8 core CPU)...but I know after update engine and instance this can be much faster, easier and better 8)
This metal ball and white boxes are testers for tonemaping and colours...in mirror You see Physky's enviromet, white box show "light is strong or weak, shadows has good colours"
khan973
Re: Grass V3
Post by khan973 »
thanks man, you rock as usual! I'll talke a look when I can and will certainly learn a lot from it, from you!
Re: Grass V3
Post by salvatore »
The texturing is amazing.
I did not know this technique
I still learn a lot from you!
thanks to share and instruct this community
BarryV
Re: Grass V3
Post by BarryV »
Thanks Janusz! :D
Really nice to post this!
And again...lots to learn!
larry_g1s
Re: Grass V3
Post by larry_g1s »
Johny...that last image in particular looks photo-real. Very nice work and thanks for sharing. I hope all is well.
ideart
Re: Grass V3
Post by ideart »
Thanks Janusz you are very generous. Great work.
sotto3d.com
Re: Grass V3
Post by salvatore »
this si my test grass with more layer
I mix Janusz' s grass models (and edit some one) and Jure texture because the Janusz' s grass texture is too slow for my projects
I think 3 min is good
All advice are welcome
thank you very much
grass
grass
geo_n
Re: Grass V3
Post by geo_n »
I tried to render this scene. Many updated kray features when loaded are missing. It turns up just black when rendered. Build 1207 lsc.
Re: Grass V3
geo_n wrote:I tried to render this scene. Many updated kray features when loaded are missing. It turns up just black when rendered. Build 1207 lsc.
Please remove all your kray* plugins and delete kray*.lsc and kray.p files from disk. Then download and install again plugin from website.
geo_n
Re: Grass V3
Post by geo_n »
Ok that worked. Thanks.
Just wondering why the override is activated and pure diffuse and over color is checked in this scene.
jdomingo
Re: Grass V3
Post by jdomingo »
Hi Jure
is there a new version of KRAY? im using 2.1 1207
DeeL
Re: Grass V3
Post by DeeL »
Rapidshare (free download) file is broken? I can't download this file.
