Modifying UV-Maps, Bug?
joschy3d
Post by joschy3d »
Hello,
I was just baking some textures and modifyed the automatic generated atlas uv-maps from lightwave. After reload the object kray only see the automatic generated UV-Map? When I check the uv-map within the modeler I see the modification I´ve made, kray not. Is this a bug?
greetings,
joschy
Try removing Kray plugin and see if that helps...
joschy3d
Post by joschy3d »
Yes, that´s help. Thank you!
