material sampler
Here you can share your Kray related materials, scenes, objects or whatever you think may help other users on our forum.
albertos2008
material sampler
Postby albertos2008 » Thu Jul 03, 2008 4:40 pm
hi to all...
I'd like to start something useful...
in this forum we discuss a lot about light settings, but non so much about material creation
I want to share a material sampler scene to contribute creation of a material library
I also upload some samples.. (srf are included in scene)
albertos2008
Postby albertos2008 » Thu Jul 03, 2008 4:46 pm
here's the scene....
material sampler.zip
(182.03 KiB) Downloaded 1341 times
Pheidian
Postby Pheidian » Thu Jul 03, 2008 4:58 pm
Great job and very good Idea indeed!
You basically got all the basic materials there, from with a little tweak everyone can create everything :)
btw, scene has some maxwell surface options plugin I dont have, as well as some missing textures... would you please check this again?
albertos2008
Postby albertos2008 » Thu Jul 03, 2008 5:09 pm
oops!...
it seems that I leaved some maxwell settings.. but just ignore....
tha maxwell shader doesn't influence the render....
Postby Janusz Biela » Thu Jul 03, 2008 5:49 pm
oh nice!
I no have time for share surfaces.
But I member abount this.
This is good model, could You share this model, we have scene for surfaces, but for me this model is very good (no strange wire, basic, easy)
We have another floor for this.
darickster
Postby darickster » Fri Jul 04, 2008 10:09 am
nice scene, it has a bug in my lw the white light switches to yellow by just going through materials, odd. I also see it has a high spatial tolerance( 0.08 ) causing bad contact shadows and the object is floating.
Rendertime can be substantially reduced using no DOF and using higher FG and N value to compensate for bg splothes and turning off full frame antialiasing
cheers ric
albertos2008
Postby albertos2008 » Fri Jul 04, 2008 10:28 am
yeah I'know...
I've to fix something...
how can improve the contact shadows?
darickster
Postby darickster » Fri Jul 04, 2008 10:31 am
higher FG (400-800) or FG (100-400) + tailer command 'prerender 1,2,0.1;gradients_neighbour 0.1' and smaller spatial tolerance (0.01). especially spatial tolerance has influence on it.
The groundmaterial is 100% diffuse and has 255 on all colorlevels, which isnt very realistic, try a diffuse of 80% max and white levels round RGB190..
could be the ground is washing contact shadows out..
cheers
ric
Ruslan2
Re: material sampler
Postby Ruslan2 » Mon Aug 24, 2009 12:11 pm
Hi! Please help with making the material to look like velvet :)
khan973_forum
Postby khan973_forum » Mon Aug 24, 2009 5:14 pm
It looks dusty :)
you should lower he opacity and keep it white or close to the basis color.
Postby Janusz Biela » Mon Aug 24, 2009 5:55 pm
Ruslan2 wrote:Hi! Please help with making the material to look like velvet :)
Could You show example from photo?
Ruslan2
Postby Ruslan2 » Mon Aug 24, 2009 7:05 pm
This example Vray. I it is necessary to get similar result LW+Kray
Postby Janusz Biela » Tue Aug 25, 2009 8:06 am
Ruslan2 wrote:This example Vray. I it is necessary to get similar result LW+Kray
I thing this looks very bad.....
ana028
Postby ana028 » Fri Oct 16, 2009 9:31 pm
Great scene for material shaders, I think that there can be a great idea to open a section in kray web with example shaders for kray and the kray users submit shaders.
Postby jure » Fri Oct 16, 2009 11:18 pm
Ana028 wrote:Great scene for material shaders, I think that there can be a great idea to open a section in kray web with example shaders for kray and the kray users submit shaders.
Yes, stay tuned. We'll soon have something for you...
Return to “Kray depo”
Who is online
Users browsing this forum: No registered users and 2 guests
